Announcements
Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Civil 3D Forum
Displaying Crossing Pipe in Profile
5 REPLIES 5
codee
9284 Views, 5 Replies
I am having trouble displaying my crossing pipes in my pipe network in my profiles correctly. When I display the pipe in the profile it comes in a a vertical line over another vertical line. Does anyone know what I am doing wrong? The pipe I am trying to display is BLUE.
5 REPLIES 5
rkmcswain
in reply to: codee
Are you trying to show the ellipse of a pipe that is roughly perpendicular to the alignment, at a structure? If so, then don't 'draw' the pipe in profile, and it will show up by itself.
R.K. McSwain     | CADpanacea | on twitter
samir_rezk
in reply to: codee
As you can see from your screen shot of the style dialog window there is a crossing pipe in/out pipe that you should turn on, please see the screen capture highlight below:
note that in most cases you will find that the best approach is to have a designated pipe crossing style designated for this particular use, and therefore ultimately you will use the pipe crossing style as a profile view style override. the reason being is that if it is not an override you risk having the pipe not show correctly in plan or in other profile views where the pipe may be parallel instead of crossing...
Hope that helps,
Samir Rezk
Technical Support Specialist
clemus
in reply to: samir_rezk
still can not see my elippse !
crobertsHGJA6
in reply to: clemus
If it is connected to manhole and you are trying to see it the manhole you have to uncheck "draw" and not draw it. What is being shown is the hole in the manhole not the pipe.
JLAHAYE
in reply to: crobertsHGJA6
That makes sense - to see the hole in the manhole.  I dont see that in my profile - what do I need to do to display the hole in the manhole?
Rail Community
