displaying corridor links
CADmgrMike
CADmgrMike
Is there a way to display in plan view a corridor link only at the beginning or end of each different assemby?
I'm using a code set style to show the linear lines and hatching, but I need a perpendicular line between each different assembly.
Mike Porter
https://provostandpritchard.com/
sboon
I don't think so, but there are display options in the corridor style that allow you to display links at region boundaries.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
joantopo
I remember that Jeff was doing something in Sincpac about Regions. I think that the region highlighted according on the location of the cursor.
I don´t know if there is similar functionality in C3D about Regions.
Autocad C3D 2019 SP3, 2020 & 2021
Intel I9 9900K with frontal watercooler alphacool eisbaer 360 (original fans mounted in pull)- 3 fans Corsair 120 ML PRO in push.
MOBO Gygabyte Z390 Aorus Master- Corsair RGB Vengeance 64GB RAM (4x16) CL16
Nvidia Quadro RTX 4000
Samsung 970 EVO PLUS 1TB (unit C). Samsung 970 PRO 512GB (for data)
Power Supply: Corsair TX850M PLUS
Descubre mi programa VisorNET para Civil 3D:
https://apps.autodesk.com/CIV3D/es/Detail/Index?id=appstore.exchange.autodesk.com%3avisornet_windows32and64%3aes
CADmgrMike
That would be what I want to do. Draw links at each region.
I'll look into that.
Thanks.
Mike Porter
CADmgrMike
The region boundary is pretty lame. Not going to work for what I need.
I need to show lines at places like where my should ends. (see below)
Mike Porter
