Announcements
Disconnected leaders in sheets
dbartholPQYPW
dbartholPQYPW
Leaders are disconnected in my sheets but function as expected in root file. DIMASSOC is set at 2.
MSchille-1994
I downloaded your file and worked in it.  If you set the Dragged State to As Composed, you can drag the label and then drag the leader tail to where you want it.  That is the best I think you can do.
Attitude, not Aptitude, Determines Altitude
dbartholPQYPW
Thank you but I don't think that is the issue. My Dragged State is set as you suggested. The issue is when I xref the drawings in my output sheets. See the screen shots I posted.
