Disappearing Path Array element
Ingy64
Ingy64
I was simply trying to array a line element along a polyline. However, when I select array/ path/select object and then specify the path the original element disappears and I get no array.
Any ideas?
VincentSheehan
Check the DELOBJ variable.
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
J-Porter
Is it happening in this one drawing or any drawing?  Can you post the drawing so we can test?  And like @VincentSheehan stated, check the DELOBJ variable.
