Disable Warning for Alignment/Station Control
Marsay
Marsay
How do I disable Station Control Warning?
Mike.M.Carlson
I'm pretty sure you can't disable this warning prompt.  It is a fairly innocuous warning though...It just informs you that if you have Corridors, Layout Profiles, Sample Lines, etc. already based on the initial Alignment Stationing, you will have a lot of stuff to redo.
If you haven't created anything off of the Alignment yet, just click OK to accept prompt and adjust the Starting Station, etc.
I hope this helps.
Michael M. Carlson
Senior Civil Designer
CADD Manager
AutoCAD Civil 3D Infrastructure Design Professional
AutoCAD Design Professional
chriscowgill7373
Is there a particular reason why you would need it disabled? Changing reference stations of an alignment is not something I have known to be something that one does all the time.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2024 on Windows 10
