Dimensions acting funny
ESchomberg
ESchomberg
I use to be able to see dimension lines and arrows throughout the process of selecting their position. Now in 2020 The dimension lines and arrows are invisible until i make my selection of placement and final click. Is this normal? in 2020.....apparently I have forgotten how to properly do a screen cast
Joe-Bouza
Wow
I would say that isnt normal for any version.
check thwe check boxes in the options dialog maybe something there will jiggle it loose
Joe Bouza
ESchomberg
It is probably some setting that I undid trying to figure out my other issue now I cant seem to figure it out.
AllenJessup
Looks like you have to select a specific command now.
Dimension (DIM) command does not show dimension preview when using an Annotative dimension style in ...
I might have never noticed that being an old keyboard jockey. I only use the ribbon for some Civil 3D commands.
Allen Jessup
CAD Manager - Designer
ESchomberg
Thank you Allen
