& Construction
Integrated BIM tools, including Revit, AutoCAD, and Civil 3D
& Manufacturing
Professional CAD/CAM tools built on Inventor and AutoCAD
Is it possible to make any label style to get dimensions between two COGO points like showing in image here.?
I am importing COGO points on Alignment from text file after how its possible to get dimension like this Its around 300-400 points include both down and up lines.
Run a polyline through the points using the 'pn transparent command and then dimension or label that object.
Thank you for your respond can you give in details I am new for CIVIL 3D.
and also please guide how you are saying to dimension the object manual or using any different command?
can we add length of object in label?
Hi Amriya,
To put a picture to Tim @tcorey 's words, draw a polyline from point to point, and then use a line label.
Dave
Dave Stoll
Las Vegas, Nevada
We can use any method to make that PL line? Like manual or using coordinates
Amriya,
"We can use any method to make that PL line?"
Yes. In my example I just clicked node to node to create a polyline with vertices at each COGO point. If your COGO Points are in order you can use the Transparent Command 'PN as Tim suggested. If your points are not arranged in a numerical order you can use 'PO to click on each of them.
Dave
Dave Stoll
Las Vegas, Nevada
How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
Type a product name
