Different volumes using same base data
neilyj666
Mentor Mentor
neilyj666
I'm getting a discrepancy between the Volume Dashboard and the old school AeccReportSurfaceVolume.
For the latter I copied my CR-Raise Levels-Top surface to two new surfaces - Type1 Est and RipRap Est - and used the boundaries from the volume dashboard method as Outer boundaries. The total volume is fine in both cases but the individual split volumes are not in agreement and I've no idea why this should be the case as the boundaries are identical.
Clearly the volumes aren't huge but it does ring alarm bells as to the accuracy of the volumes dashboard - any one any ideas as to what is happening here?
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
samir.rezk
Autodesk Support
Autodesk Support
Hi @neilyj666
My thought is that the Mid-ordinate might be different between each method!
Samir Rezk
Technical Support Specialist
neilyj666
Just tried and it doesn't affect the volumes...🤔
samir.rezk
Autodesk Support
Autodesk Support
Hi @neilyj666
Could you post the drawing please, I am curious to take a look!
Samir Rezk
neilyj666
Can you PM a Onedrive storage link as I can't share via a public forum? I'm on holiday the rest of the week so won't be able to upload until then
