Dear all,
I have some points exported from Google Earth as KML and converted into DFX using QGIS.
I need to insert this points on an existing Civil3D drawing, but original coordinates from DFX are not detected on INSERT file dialog box.
I am using the INSERT command for this purpose.
Please, have a look on the picture.
I need your help on finding a way to insert this points and have Civil3D to automatically detect the correct points position X and Y positions.
EDITED: I also used the DFXIN command and the point is shown on correct/desired position, but the problem is that DFXIN will open the DFX file and not insert the points on an existing drawing.
I am quite sure the coordinates are on the DFX file. I attached it to this post in order for you to have a look and confirm.
Thank you very much
Regards
Paulo
