Design profile editing
I have an 8km long alignment and profile was designed using (mostly) floating straights and curves.  I now need to change a floating straight to a floating curve somewhere in the middle of the alignment.  Is there a way to do this without deleting the last 4km of my profile and re-doing everything?  With alignments, there is a way to change parameter and tangency constraints but I don't think there is for profiles?
Jeew-m
You can do this by profile geometry editor.
First add a PVI at the middle of the straight you need a curve.
Then move the PVI up or down by the amount you need for the curve.
Then go to more vertical curve--> Free vertical parabola.
You can create a similar curve as floating curve.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
Thank you Jeewana.  I however wanted to replace the floating straight with a floating curve.  I should have explained too that the profile is mainly made up of floating elements and I want to edit the middle section of the profile.  But the only way to do that (as far as I know) is to delete the floating components from the end back to the section I want to edit.
Horizontal alignments have the option to change tangency constraints between fixed, floating and free so you can easily delete/edit anywhere along the alignment but profiles do not have this option. I'm using C3D 2018 and don't think 2019 and 2020 can do this either(?).
morning,
you are talking about a vertical alignment.  and Jeewana is correct.
Add a vertices to your vertical alignment, and then using the node grips move the new point up/down to the pvi location.  Using the vertical alignment editor you can change the slope in and out of the pvi, then add a free floating vertical curve of any length.
Select your vertical alignment, right click your mouse, select Edit Profile Geometry.
Add a new vertices where needed, select vertical curve - free floating.
And you are set to update / add labels.
good luck,
nonbeard13
Thanks Nonbeard but like I said, my elements are all floating so I can't add a PVI.
Jeew-m
Ah... I always go with parabolic curves with free vertical parabola. They are easy to edit.
However in your case I have little suggestion.
Create a ASCII file for your profile. Refer links as guidance.
Link 1
Link 2
The use import from file option to create the profile.
So you will get the same profile without floating options where you can add/edit PVI in the middle of tangents.
Jeewana Meegahage
Design Engineer
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
