Civil 3D Forum
Demystifying the Coordinate system : When is it applied in Civil 3D or Map ?
23 REPLIES 23
Message 1 of 24
cyberflow
1087 Views, 23 Replies
Hi there,
I know how to assign coordinate systems to my drawing, no problem.
But i'm trying to figure out when does Civil 3D work with coordinate ?
Is it when we create points when importing a survey ? When draw alignments ?
Or is it that we always work in a plan grid and then when we want to export there's a transformation applied ?
Thanx all in advance !
It's a pretty hot topic sometimes that is configured by a surveyor on a projet and we stick with that CS (coordinate system) for the life of the project without questionning ourselves.
Frank Freitas
CAE/CAD/BIM Coordinator & Support Specialist
LinkedIn
Labels (3)
23 REPLIES 23
Message 21 of 24
cyberflow
in reply to: cyberflow
Hi Dave,
"vertical transform between a NAVD88 and a CGVD2013"
I just browsed the tool and didn't find anything either ...
But there's a way of using .byn files from the canadian instances that take care of Datums and convert it into bin
Afterward it's just a question of adding that into the .json file so the tool shows up the new .bin files
I haven't tested this though
"the transform tab is really only for import point"
Ok, I did some reading and the transform tab really affects when we insert something in the drawing after that the objects have been transformed.
-LandXML ?
-Copy/Paste with base point ?
-Binding Xref ?
-Importing text for Cogopoints
I think it's about it for the effect of that tab ?
Frank Freitas
LinkedIn
Message 22 of 24
cyberflow
in reply to: Pointdump
Frank Freitas
LinkedIn
Message 23 of 24
Pointdump
Frank,
I found the site that stores Geoid files for the entire world. In theory you can download any file lacking in the Vertical Transformation Tool.
>>>International Service for the Geoid<<<
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Message 24 of 24
cyberflow
Dave,
Excellent find !
A nice Geoid repository !
Except for Canada it's on demand - Ive did the demand for those files to see if i can have them and integrate them with C3D - Will keep the forum posted on this :
I've redone some browsing and searching on this - and can't find no more details other than how to configure that tab.
Frank Freitas
LinkedIn
Rail Community
