DEM vs XML from Same Surface
nkg2
nkg2
So I wanted to extract a surface from another drawing to create a new drawing.  I exported the surface in both DEM and LandXML.  Essentially they look different but the data appears to be close as you can hover over every line that would be assumed overlapping and not but the elevation difference might be like .2' different.  The boundary of the surface is also interesting since they both were created from the same surface so my question is what is more accurate when exporting a surface a LandXML or DEM?
Edit:  Here is a snapshot of the difference:
***Viewer/Reader Discretion is Advised***
Autodesk 2025- Architectural, Engineering and Construction Subscription & Infraworks
Windows 11 Professional, x64, Microsoft Surface Studio 2
jessica.miller
We work with landxml all the time.
Jessica Miller
Design Technician
CEC Corporation
4555 West Memorial Road, Oklahoma City, OK 73142
T: 405.753.4200
Dir: 405.753.4616
www.connectcec.com
rl_jackson
Can you post the files.... My guess is it's the drawing units or INSUNITS not equal to 0
Rick Jackson
Survey CAD Technician VI
fcernst
GRID  vs TIN surfaces
Fred Ernst, PE
C3D 2026
Ernst Engineering
www.ernstengineering.com
