- Mute
- Permalink
- Report
I was tasked with trying out C3D 2021 because the company license is renewing at the end of the month and we'll be losing the use of C3D 2017. One of the major workflows is to import lidar data and create a surface. I was able to complete that workflow and create a surface by processing the lidar data in Recap but C3D will not allow the data to be filtered by classification so its not possible to use only ground data.
I used the "MAPCREATEPCSURFACE" command that will allow the data to be filtered out by classification and created a DEM and plan to use that to create a surface. The problem is that when I create the surface from the DEM it doesn't populate at the correct location. The DEM is in the correct location but the surface doesn't drop on the DEM but is approximately 1,400 miles Northwest. I have tried several things but am not able to figure out why the surface doesn't overlay in the same location as the DEM. Any Ideas?
