deleting empty layers in a layer filter
allywhite666
allywhite666
I am trying to delete all the empty layers in a layer filter and ONLY in that layer filter, not the whole drawing. Is there a quick way to do this or is there a command that I can add to the layer filter that will filter out the empty layers and only show the layers that have something in them.
I thought that "All used layers would do this" and I could add its command "USED == "TRUE"" to my existing filter but this does not filter out the empty layers even in the original filter which is automatically created by AutoCAD.
Any help would be appreciated.
Thank you. Smiley Happy
Ajilal.Vijayan
Create a new Property Layer filter under the Layer filter where you like to see the empty layers with the filter definition status 'Unused'.
Spoiler
And goto Layer settings and tick 'Indicate layers in use' to show the 'Unused Layers'.
Spoiler
May need to refresh the Layer window to update the filter,
hope this helps.
allywhite666
Thanks for the reply, this works well.
Ajilal.Vijayan
You're welcome
Glad I could help.
