delete pipe network
delete pipe network
marlance
Message 1 of 11
delete pipe network
marlance
How to delete multiple pipe network in the prospector tab?
Replies (10)
Message 2 of 11
sirjoelsph
Highlight up one row from where you are just on "Networks".  The full list of networks should show up on the bottom of the prospector tab where you can highlight multiple networks using Ctrl or Shift, then right click and select Delete.
-JOEL
Message 3 of 11
marlance
Thanks Joel
Message 4 of 11
marlance
Follow up question.
Is it possible to create multiple reference in data short cut?
See image below
Message 5 of 11
sirjoelsph
Unfortunately no quick way of doing multiple shortcuts.
-JOEL
Message 6 of 11
marlance
is that possible thru lisp or any other way?
any way thanks sirjoelsph
Message 7 of 11
yuben112
Four years later in 2019.
I tried following your direction and it didn't delete multiple pipe networks but only the very bottom one network. I am using Civil 3D 2018. Please advise. Thanks.
Message 8 of 11
sirjoelsph
@yuben112  - you're right.  I just tested it out in Civil 3D 2018 myself and get the same result.  It deletes one network and them somehow prompts me to pick an object in another network and will delete that one, but then the command ends.  I definitely don't remember this being the behavior 4 years ago.  I, unfortunately, don't have another workaround since this has changed.
-JOEL
Message 9 of 11
Neil.Aryan
Hi Sirjoelsph,
I am not sure why the solution post doesn't work but I found my own way to deal with this and I found this way is very much useful and informative for my pipe and pressure network design.
Create folder and move all unwanted networks into the folder and delete whole folder. this should works.
When you click on delete folder, delete sub folder dialogue box appears and you must choose the option dele all objects.
This video explains the procedure,
https://www.youtube.com/watch?v=0-53O1GVZus
If you still not able to delete feel free to upload the file for better understanding and best resolution.
Did you found this post is unique ? Hit Like Button.
Did this post resolved your issue? Hit Accept as Solution & Like Button. This will be helps others to solve the issue.
Cheers,
Neil
Founder Director | Neil Engineering Consultancy
Certified Civil 3d Professional | (Old) YouTube | (New) YouTube
Message 10 of 11
Neil.Aryan
Hi Yuben112,
Cheers,
Neil
Message 11 of 11
Neil.Aryan
@marlance
Cheers,
Neil
