I can't find where anybody has figured out how to show the deflection anglesof alignments. I want to show those angles in band set or profile view.
Can some body help me with this?
Thanks.
Solved by Jeff_M. Go to Solution.
Solved by wfberry. Go to Solution.
You can get the deflection angle in your [Plan] P.I. Label using the Tangent Intersection style.
Bill
Thanks bill for your reply.It is correct for plan.I did not know until your post.Thanks gain.
But actually I want show those deflection angle(or delta angle) in profile BAND set or to show some how in profile view.
Is there any method?
Any idea wellcome?
Looking under Band Style, Horizontal Geometry, Geometry, I noticed a "Delta Angle" property for an alignment.
Bill
Hi bill,
Unfortunetly I am using Civil 3D 2011. I think in 2011 there is no option like "delta angle" like below image.
Since alignment does not have curvers I should use tangent section of label style.Pls give me picture of 2012 of above label style?If it is working iI TRY to move to 2012.
Big Thanks for you.
Is there any method to do above thing in 2011?Pls give some idea?
Your questions would then be best served if you took the time (this goes for everyone!) and fill out the "MySettings" above right on this page.
Notice the info below my name. Enter it one time only.
Bill
Thanks all for helpping.I wii try to get Civil 3D 2012.
Futher Is this possible ?
If angle between
I want to add those numbers(11.5,25...) as band style of profile view of alignment.Also
can add direction of angle to band style?
Thanks for your time.
I don't know specifically for this, but I think you should investigate Expressions for this kind of thing.
Mark Green
Working on Civil 3D in Canada
Hi all,
There is no option to use expression (2011) in band style .
Is it in 2012 or 2013?
