Define Variable and Set Variable Values Difference
mwasimakram786
mwasimakram786
Hi All
I am new in SAC Can someone explain Difference between Define Variable and Set Variable Values in SAC.
And this both which situation we will use.
Regard.
camden.n.dean
i haven't been spending much time in SAC recently, but it sounds like:
1) Define Variable: create a new variable and (possibly) assign a value
2) Set Variable Value: assign value to existing variables
-camden
ecfernandez
Hi @mwasimakram786, I hope you are doing well.
The difference between them is that when you define the variable, you can set a default value you can work with and create your geometry, whereas the set variable value becomes important once you have already defined a variable that needs to be changed to build geometry if something changes.
As an example, you can define the thickness of a lane layer as the sum of two input parameters through a variable. However, under certain circumstances of cut or fill height, you might prefer layer thickness to have a different value. For such a task, you would assign the variable (inputparameter1+input parameter2) to the layer thickness. Then, you would evaluate a Decision for testing cut and fill height, so if the value exceeds a defined range, you would use the set variable value to make the layer thickness bigger or smaller.
I hope this helps. Best regards!
Camilo Fernández
Civil engineer | Specialist in design, construction, and maintenance of roadways
LinkedIn
