Now that the C3D UKIE Country Kit 2024 has been released it is time for the annual frustration of transferring my settings over from 2023 to 2024. It was going well until I tried to amend the default right click shortcut menu - I had the same issue with 2022 to 2023 but i can't remember how I resolved the issue.
I have my right click settings in a cuix file and I dragged and dropped into 2024 and they appear as expected
However when I click in the blank drawing window (nothing selected) the following menu appears....
...which corresponds to the right click menu for edit mode...
... I checked my Right Click Customizations and they look ok i.e. Default mode should select the shortcut menu
Can anyone shed any light on why this is happening and more importantly how to get around it - I'm sure it is a simple fix but I can work it out at all?
Neil
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
