Hi y'all,
I have been working with Civil 3D in decimal and engineering units. When I type in 500 not 500'. My input is in inches, not in feet. I only deal with ft and I don't want to put ' (ft) at the end of all the numbers. I tried -dwgunits and -dimsty. None of it is working. Please help me with this.
Thanks in advance.
Solved by samir_rezk. Go to Solution.
Solved by rl_jackson. Go to Solution.
What's your setting if you type units and hit enter?
@chun2612,
Welcome to the Autodesk Forums.
"Engineering" units are decimal inches, and Civil 3D wants nothing to do with them. Best to stick with "Decimal".
Dave
Dave Stoll
Las Vegas, Nevada
To add to what @Pointdump , you should also set the pull-down for insertion to UNITLESS.
Also, please note, all the settings for units should be controlled by the Settings Tab, Right-Click the Drawing name, and select Edit Drawing Settings - From there you'll be provided with the Units and angle along with a coordinate system if you so choose.
Rick Jackson
Survey CAD Technician VI
