DaylightInsideROW Targets
AllenJessup
Mentor Mentor
AllenJessup
I'm using the DaylightInsideROW to daylight to a range go grading until hitting a Target Alignment.
I have 2 Offset Alignments to use as targets. However the daylight defaults to the maximum grade, 4:1 and bypasses the Alignments. I have a test alignment shown below.
The Offset Alignments are shown as white in plan and red dashed lines in section.
It shows in both cases the grading going past the Target Alignments.
This is how I have the Targets set.
What am I missing to make the Daylight hit the Target Alignment if the maximum grading will go outside them?
Allen Jessup
CAD Manager - Designer
Joe-Bouza
Aint that annoying
Joe Bouza
RobertEVs
Try using DaylightMaxWidth
This subassembly inserts a link that daylights to a target surface at a user-defined cut or fill slope.
If necessary, the slope is adjusted to keep the daylight point within a maximum width from the hinge point.
AllenJessup
@RobertEVs That's the problem. While in my test Corridor the Offset Alignments are at a fixed width. In the project I'm working on the Target Alignments are not at a fixed width.
Allen Jessup
fcernst
Is your Hold Slope parameter set to Override Maximum Slope?
Fred Ernst, PE
C3D 2027
Ernst Engineering
www.ernstengineering.com
AllenJessup
Thank you again.
Allen Jessup
