DAYLIGHT OVERLAPPING IN ZIGZAG ROAD PLEASE HELP.....
imran_tamrahi
imran_tamrahi
HELLO DEAR ALL
FIRST OF ALL I WOULD LIKE TO THANK ALL AUTODESK FORUM USERS FOR THERE GREAT EFFORT TO HELP OUT PEOPLES LIKE ME WHO ARE NEW TO CIVIL 3D. NOW I COME TO THE POINT.
I AM FACING ISSUES IN ZIGZAG ROAD DAYLIGHT AS ATTACHED PICTURE.
DAYLIGHT OVERLAPS ON SAMPLE LINES IN EAGLE POINT IT DOES NOT MATTER BUT IN THIS SOFTWEAR ITS A MAJOR ISSUE YOU CAN SAY BLUNDER IN EARTHWORK. PLEASE HELP ME OUT TO SOLVE THIS PROBLUM. I ALSO WANT TO MAINTAIN MY DAYLIGHT BENCHING IN THIS OVERLAP PORTION.
THANKS
redtransitconsultants
This is a common issue, referred to by the community as a "bow tie". The issue is the projection to the left of the alignment is larger than the radius that you have on the alingnment - thus this design really does not work.
A couple of solutions would be to
  1. Steepen the slope in this area to allow for the projection to be a shorter horizontal distance
  2. Increase the radius size on the curve to something larger than the projection that is occuring.
Steve Hill,Civil Designer / .NET Developer / AutoCAD and AutoCAD Civil 3D Certified Professional
http://redtransitconsultants.com/
Autodesk Exchange Store
Twitter | LinkedIn | YouTube
mathewkol
If it was a simple slope you could remove the daylight subassembly and do the daylight with heading objects. If you're benching, this is more difficult.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
imran_tamrahi
actualy sir this design is implemented at site. Contractor excavated half of workdone on this design there is no way to main my deisgn as it is
in eagle point toe in overlapped but in sections of eagle point it does not reflect but in civil 3d this problum occurs that it overlap in section view
how can adjust the design.
sboon
The cyan line in your sections is the corridor surface.  The jagged area would be where the different corridor sections are crossing over each other.  Change your surface style to show TIN lines in plan, and you'll see the problem more clearly.
If you're already in construction, and you have to fix this you basically have three choices - either a miter, chamfer or fillet in the area between the two white lines.  There are advantages and disadvantages to each - you need to consider the cost of extra excavation, reduced width of benches etc.
You will have to create a surface within the area, using featurelines or grading and then paste it into your design.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
