Daylight Bench Subassembly when wall is <3' high
RobertEVs
Advisor Advisor
RobertEVs
Can I omit the wall in my DaylightBenchSA when a condition Max Fill Height of less than 3' is met and instead have it grade out at 1.5:1 to my EG? I get these smaller height walls when when building my corridor. I would like to have the SA build the first 3' wall and when another 3' wall is unmet grade out instead.
ecfernandez
Hi @RobertEVs, it seems to mee that you can do that with the following nested conditional configuration:
Place a cut/fill conditional at the first green dot on the edge of shoulder. Test if fill is big enough to place those two yellow links or if you need a different geometry (You can play around with the minimum distance and maximum distance of this conditional to have multiple geometries being inserted for several ranges of fill height) Based on your image, you'd place those two links starting at a fill height (min distance) of at least 6m.
 Then, at the end of your second yellow link, you could place a conditional that evaluates again what the fill height is, and decide if it is greater or minor than 3'. Depending on that, you could place multiple ranges again that give you the desired result. In this case, if it is less than 3' it would grade out at 1.5:1 to EG.
I hope this helps. Best regards,
Camilo Fernández
P.Eng | Transportation
LinkedIn
RobertEVs
I think this would work. I'll try it later and report
