Data Shortcuts Through OneDrive
Has anyone had luck setting up Data Shortcuts through OneDrive?
I have a project that I setup on a shared Onedrive Folder. I have synced the folder to my local computer and set up a data shortcut folder the various elements like surfaces and pipelines. Problem is that anyone who tries to access the files with any data shortcuts in it get hit with broken references for the data shortcuts. (The normal Xrefs work fine by the way.) On a local server we don't have an issue with this as we are both accessing the same file on a map network drive so it works just fine. But a cloud based folder "maps" differently. C:\Users\abc whereas another users cloud folder would be C:\Users/xyz. I thought data shortcuts were suppose to be relative but I know the xml files for the data shortcuts save a direct path. Anyway to make them truly relative?
Does anybody no about a workaround for this?
