For most of my design projects I create the existing surface within my existing base file. From there I use data shortcuts for other files (like the site plan, grading, utility, landscaping, etc.). In my grading base, before I begin creating my proposed finish grade surface, I usually create a reference from the data shortcut of the Existing Ground Surface.
In every application of this process, I have not had any issues, and I'm able to tell my proposed surface to either project to the existing surface along my end area conditions, or even to drape my boundary lines to the existing surface once it is referenced into the drawing.
In this particular file, when I try to create the reference of the surface from the data shortcut, it creates the reference surface, but it is offset from the original surface file. I'm not sure why it does not match up with the surface it is referencing, and I don't know how to solve this issue.
I've never run into a situation where the reference created from the data shortcut, doesn't line up with the data shortcut.
Please help.
