We recently had a problem on one project that causing Civil3D to shutdown without even through unhandled exception.
After several trails we were able to reproduce the problem and realize there might be something to do with the data reference being on our server.
We have two files and data shortcut on our server
File A.dwg - contains original file contains 141 alignments as well profiles data
File B.dwg - contains all the 141 alignments and profiles referenced in from File A
User D is working in File B while another user B is in File A. When user B finished and save the File A, the Civil 3D application will be freeze and shut down on user D. The message on the right bottom corner saying "data shortcut is out of date" didn't even show up on user D's Civil 3D.
We also tried to bring all files and data shortcut folder to local drive and tried on open both file and save File A, the message on the right bottom corner will pop-up and Civil3D didn't shut down.
In this case I assume there's something on the server that limits the communication between data shortcut files, but I'm not sure how exactly how it works. We are trying to test out on our server about the maximum number of data shortcuts can be store in one file that won't cause another file to crash when save.
Is there any suggestions on this?
