I have a pipe network in a base file that I have data referenced into a design sheet. It is not attached to any alignments in the base file. When I try to associate the structures of the referenced pipe network with the alignment in the design sheet (not a data referenced alignment) it will show the stationing and maintain the reference but once any other data reference is synchronized or the sheet is saved and closed it loses the reference and the stationing shows up as question marks. How do I fix this? These pipe network structures will appear in other design sheets and be associated with other alignments in those design sheets so I can't refernece it to the alignment in the base file that contains the pipe network or else it will be referencing the wrong alignment in different design sheets.
Additional info/background:
This is a public roadway set. So any manholes or inlets on or near intersections will show up in multiple plan and profile sheets hence the need to be able to reference multiple alignments based on the sheet the pipe network is data referenced into.
