Hey Guys!
In a quite big project (33 km new highway and related roads) with 5-6 road designers working on it, we figured out a workflow which seems to fall into pieces.
The whole project is in separate model files, we dref everything, and there are clean files (so there are no drafting lines to delete and using the final style, annotate etc.) for only output purposes (export, printing etc.)
The problem is that the corridors do not appear the same in the model files(dref host) and the output(dref client) files. Same code set styles are used in both files via style referencing, and the host file works perfectly, but in the client files, at corridor region ends the feature lines switch sides for unknown reasons, even though the codes don't change. Links and surfaces work perfectly only feature lines go crazy. We use custom pkt subassemblies, but we could replicate the problem with built in elements.
I attached some images to understand the problem.
Has anyone met this anomaly or has any idea what's wrong?
I'm a long time surfer, first time poster here and english is not my native language, so please be gentle. 🙂
Thanks in advance.
