Civil 3D Forum
data band in profile view doesn't show data, HELP! what should i do?
4 REPLIES 4
tommf12
1290 Views, 4 Replies
im using Civil 3D 2020 (on windows 10), i'm trying to create a sewer pipe network.
i create for this a data band set that shows all the data that i need in the profile view.
however, in some profiles it work just fine but on other profiles it doesn't show any pipe data at all, even though i use the same steps the intaier way... what could be the problem? what am i missing?
(i repeated the entire process many times just to make sure)
4 REPLIES 4
ilia.borisov
in reply to: tommf12
For K21-K35 you have to add data source in profile view band, for K19-K17 i dont know your workflow but think you dont have pipe network for that(create one and then add it the same way as K21-K35 in profile view band)
lynn_zhang
Hello @tommf12 ,
Just checking to see if your problem has been solved. Did the response from above help answer your question?
Lynn Zhang
tommf12
in reply to: lynn_zhang
Yes! Thank you very mutch!!! Sory for the late response, this was the problem, im really appreciate you taking the time to answer my question
Thanks for posting this.  That data source tab was turned off for me, why would something so important be off??
Rail Community
