Cut fill study for commercial sites?
Chaznsc
Message 1 of 19
Chaznsc
I have a site with a substantial cut fill ratio, pavement, building, etc. I am curious how you guys approach your earthwork in regards to TOPSOIL, NOTCHING OUT FOR PAVEMENT, etc. I am used to doing a surface to surface comparison but would like to get down a little closer on this site.Can this be done as a whole and not have to parcel out the topsoil and pavement sections in a separate calculation?
Any advice is appreciated.
Replies (18)
Message 2 of 19
tcorey
Have you discovered Surface Pasting? You can combine OG and various FG surfaces to make a single composite. This method would allow you to "notch out for pavement, simply by creating a surface from a corridor and then pasting that surface into the composite.
For topsoil, use Raise/Lower Surface command, lower the topsoil thickness, and then paste into the composite.
If you don't want to modify the topsoil surface directly, make a new surface, paste topsoil, and then raise/lower the new surface. It's better than copying topsoil surface, because this new surface will update as the topsoil surface is modified. If you copy, the new surface becomes independent.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 3 of 19
Joe-Bouza
this should be of interest to you
http://au.autodesk.com/au-online/classes-on-demand/class-catalog/2012/autocad-civil-3d/the-magic-of-...
Joe Bouza
Message 4 of 19
neilyj666
I use the dynamic differential TIN technique as suggested by @Joe-Bouza
Unfortunately as Civil 3D is geared for extracting datum surfaces from a corridor if you don't have/need a corridor it takes a bit of upfront work to prepare but it is very useful technique.
I use it to create base of topsoil models using the sampled depths at each sample location rather than just dropping the entire surface by a constant value.
I also used the technique last week to create a landform that was dynamically linked to a reference of the initial formation model resulting in a cut/fill balance for earthworks (from a surplus of 118,000m³) which probably took less than 15 minutes to do (and wasn't simply dividing the surplus volume by the area and raising the model by a constant value which would give an odd step at the boundary...!!!!!).
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 5 of 19
M_c3d
The way we do cut & fills;
  • Model the existing ground;
  • Model the proposed roads, feature lines etc into a proposed levels surface
  • Data shortcut & paste these into a cut & fill drawing
  • Create a top soil strip surface & paste the existing ground & lower it what ever the depth of top soil is
  • Create a proposed formation level surface
Then we either do one of two things to model the proposed formation level;
1. Calculate the average depth of construction and paste the proposed levels surface into the proposed formation level surface and lower the surface to this figure
or if we have the time and there is the requirement for this;
2. Get the boundaries for each type of construction (building, roads, permeable roads etc) and make a formation level for each type with it lowered by each construction depth. Then make a combined formation surface
Step 2 is made easier by the fact that we do a 'scope of works' drawing that is a series of hatches for each construction and the boundaries from this are used as the boundaries for the formation surfaces (offset 10mm so that the combined surfaces don't overlap).
We then do an analysis of the top soil strip (base surface) versus the formation level (comparison surface)
Message 6 of 19
neilyj666
I'd be more comfortable with method 2.....Smiley Wink
As you have completed the tedious step of creating the boundaries with the crucial 10mm offset you are only a couple more steps away from the dynamic differential TIN method....Smiley Happy and you don't need multiple copies of the formation surface with many Outer/Hide/Show boundaries to model the various construction types.
I've lost count of the number of "cut and fill" drawings I've seen that say "based on existing ground to finished levels"....Smiley Frustrated
Message 7 of 19
MikeEvansUK
All good advice so far so I'm not sure what I can add..
Existing;
What you do depends on what is on the existing site. If it is all grassed then raise / lower is simplest however other instances of concrete pads or roadways we use the differential method.
You also may need to take into account geology results.
Stockpiles or mounds, you may want to remove these but note the volumes before hand.
Proposed.
First model the site finished platforms & create a new surface pasting the finished one into that, lower by the approx. average construction depth across the site. Now create a volume surface between the eg Stripped and approx datum.
Based on the results raise or lower the datum until you get as close to zero as is reasonable noting the level change.
Change the proposed surface to suit by remodelling to this value, remove the original raise lower edits and check the results tally up. (reiterate until you get close to zero).
Now I usually turn to the differential modelling technique to prove the level drop and use the raise lower again until you meet a close to zero value before remodelling anything.
I find that guessing using raise lower cuts down the remodel time until the last couple of iterations before you are within 200-600 **** of material. I have never actually managed to get zero 🙂
Other things to note; you may have stockpiles of material which can be used in construction so remember these volumes and use a spreadsheet to calc them out.
Use landxml or Dref the surfaces. Keep the, existing datum model file, proposed finished, proposed datum and cut and fill files separate to reduce sizes. The other benefit to this is you can keep the previous incarnation of the design and overwrite the xml file but importantly return back at any time.
M
Mike
Mike Evans
Civil3D 2022 English
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
Message 8 of 19
M_c3d
Its the first time I've seen the dynamic differential TIN method, definetly something I'm going to look at.
I agree, cut & fill is not existing versus proposed!
Message 9 of 19
MikeEvansUK
Is the forum using software which automatically sensors what it thinks is a rude word?
It says in my post " 200-600 ****" which should have read 200-600 c um (with no space). It was definitely right when I clicked post.
M
Mike Evans
Message 10 of 19
neilyj666
You just need to assign a construction thickness value to your boundary polylines (which must be +ve) and then make a thickness surface from these. You will also need polylines at 0 level to define the extremities of the site and then create a Volume Surface with this thickness surface as the base surface and the finished as comparison.
Paste the Volume surface into a new surfaces (Proposed Formation) and you have all the section/profile tools available as well which you don't with a regular volume surface.
Message 11 of 19
neilyj666
LOL - nanny state gone mad....!!!!!
Message 12 of 19
M_c3d
It definetly sounds like a more positive way of doing it. Will give it a go, thanks for the tips
Message 13 of 19
neilyj666
No worries - it's worthwhile getting to grips with it....very powerful technique
If your road construction thickness changes from 450mm to 600mm for example then the polyline elevation for the road areas gets changed to 0.6m and all the models update.
Message 14 of 19
M_c3d
in that case of going from asphalt to permeable construction 450mm to 630mm depths, could this be done as two seperate road areas?
Message 15 of 19
neilyj666
Absolutely...if you have the perimeter boundary of both types, simply create the 10mm offset and then assign 0.63 and 0.45 as the polyline elevations. You will essentially have two lines 20mm apart in plan and 0.180m in elevation. The horizontal distance avoids the vertical step in the TIN and makes little or no difference to volumes in practice.
You can also then run profiles and show level differences or even a level differences plan with the various construction thicknesses analysed.
Message 16 of 19
MikeEvansUK
That's the beauty of this method. As the areas of construction change on the site you don't necessarily need to re-do the surface model just the depths (which are 2d and can be harnessed as parcels or as hatched areas for construction plans.
Ensure you include a small gap between them so they'll transition out.
I liked it so much I wrote a tool to create the dynamic surface for me using 2 base surfaces.
M
Mike Evans
Message 17 of 19
neilyj666
M
I'd have hoped Autodesk would have come up with something for this technique.
It's way beyond my competency but I wouldn't have thought it was too onerous for Autodesk programmers as not all modelling is corridor focussed.....but wait.... it isn't Infraworks or 360 so no chance of it happening any time soon...!!!!
Message 18 of 19
Joe-Bouza
You a bad boy Michael 😳
Joe Bouza
Message 19 of 19
Joe-Bouza
@neilyj666 it can be tidious but worth the effort in the early going to check balance 👍
Joe Bouza
