Cut and Fill Volumes
I have a final surface and an existing surface. There is a 8" base course for the road and surrounding areas. I did a cut and fill for my surfaces but now I need to do the same thing without the 8" base course. How do I go about that?
sboon
Is your final surface defined by grading or a corridor?
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
neilyj666
This is a perennial problem with Civil 3D - can be easy if you have a corridor but trickier if you haven't.
There are a few techniques available including a Differential dynamic TIN (google it or search the forums) or you can compute the area, multiply by the thickness to derive a volume and add alegebraically to the net volume you have calculated - the net volume is cut minus fill and could be +ve or -ve.
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Its define by a corridor
sboon
If you built the assembly from OOTB subs then you should be able to create a Datum surface for the corridor.  Datum is usually the underside of all road structure, so that would exclude your base gravel.
Create a new corridor surface, add Datum links as breaklines, and make sure the Bottom option is used for overhangs.
Steve
Steve
