Cut and Fill amounts on a 10 x10 grid
How do I get cut and fill labels on a 10x10 grid?
Replies (8)
Simon_Blain
Make a volume surface
Label the volume surface with spot elevation on grid
wfberry
Check out making a Volume Surface.
Contours (Surface) represent cut / fill.  Use a surface label at your 10 x 10 s intersection.  If you are not familiar with this, the "0" contour represents the no fill/ no cut line.
Bill
autoMick
@Simon_Blain and @wfberry are on the money if you want to just label the cut or fill depth. I would add that you should grid the surface first so that the label is indicative of  the average grid value rather than the value at that exact point which might be slightly different (I hope this makes sense).
However, I took it that the intent is that the label has the volume within each 10x10 grid, so need to multiply the grid elevation by 100 using an expression.
Regards
Mick
Civil3d user in Australia since 2012.
neilyj666
You could also look a the Earthwork Plan Production tool in 2019 (and perhaps earlier releases)
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2025 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
autoMick
Interesting - I've never explored that one. I notice that even though I'm using metric, the settings indicate feet. However if I enter 10 feet as a grid spacing, it comes out as 10m - so it's using the drawing units.
BTW that too is available in 2018 as well.
Mick
neilyj666
Yes it interprets the spacing as a metre if using metric.
I've never really got results I was totally confident with when using this tool so rarely use it
autoMick
Actually, to correct my previous suggestion - I had a assumed that saving a grid DEM of the surface at 10m intervals would give the desired result (i.e. square blocks of average elevation), but a quick check indicates that that's not quite what you get back when you re-load the DEM, so some experimentation required there.
On the labelling front - I did a screencast, and in so doing found some pre-existing labels in the country kit for cut/fill elevations which are easy to modify.
Cheers
Mick
AllenJessup
I see it's available in 2017. But I've never used it.
Allen Jessup
CAD Manager - Designer
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
