Cut & Fill Volume Check
nostupidquestions
nostupidquestions
Is there any way to check cut & fill volumes? I've got 2 surfaces, existing and proposed, and I've used the Volumes Dashboard to get my cut & fill volumes. Is there a way to check that number to make sure it's accurate? Back in the Land Desktop days there were 3 ways to check volumes and I always did that just to make sure I wasn't way off.
Intel(R) Xeon(R) W-2245 CPU @ 3.90GHz 3.91 GHz
64 GB RAM
C3D 2023.2
Joe-Bouza
What did we do in LDT? I forget.
IMHO, you best check is to examine you FG Triangles, for errant that span large areas.
look a the front view for any crazy spikes both EG and FG
Does a order of magnitude check make sense? purely engineering judgment area/ depth quick calc
You can run an alignment a sample lines but I think that may frustrate with varied results. If used the spacing will have a huge effect on the answer
Joe Bouza
nostupidquestions
The surfaces look fine. I cut a profile through the site and it looks fine. I've been trying to figure out how to get volumes from cross sections but it seems like it involves materials and lists and such. Seems more complicated than it ought to be.
I think the old LDD used points, grids or average end area. The number could still be wrong but if all 3 were close to the same at least I could show that. With the Volume Dashboard it's just a number that I can't check. Time to break out the planimeter I guess.
64 GB RAM
C3D 2023.2
BrianHailey
In LDT the three methods where (if I remember correctly), TIN, Grid, and Section. Tin is by far the most accurate (assuming the models are accurate - GIGO). Grid was there as an option so you didn't have to spend hours calculating your volumes on that new 386 with 64 MB of RAM you just got. Sections were a way to duplicate the way we used to calculate volumes back when we were hand drafting. You can still do all three. When creating a volume surface in Civil 3D, you can choose either a "TIN volume surface" or a "Grid volume surface".
As for the section method, it's a bit more complicated but you can still do it. Create an alignment that spans both surfaces, create sample lines that sample both surfaces, and then use the "Compute Materials" command.
The Grid and Section options will give you an approximate volume of your surfaces and the TIN option will give you the mathematical exact volume between the two surfaces. If it gives you bad volumes, then you have bad surfaces somewhere.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
neilyj666
REPORTSURFACEVOLUMES if I recall correctly - I've added to my ribbon so not sure of the command
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
nostupidquestions
I ended up creating cross sections every foot and getting a volume that way. It comes out pretty close to the Volume Dashboard. The boss was having a cow about the amount of fill needed to fill in a site and I wanted to be able to show him some numbers that I could back up. Thanks for the help.
64 GB RAM
C3D 2023.2
