customize profile view style like a sample
arman_zmn
Message 1 of 10
arman_zmn
Hello Everyone,
I have a problem with a project, hope you guys can help. I need to create a profile style similar to this sample.
I can create bands to show the elevations at an interval, but cannot make it show all the elevation changes in the profile line, in the elevation bands.
Can anyone help?
Anyone have template similar to this?
Replies (9)
Message 2 of 10
Alfred.NESWADBA
Does that mean that you'd like to see the text with elevation at the profile vertices?
- alfred -
PS: if you upload a dwg-file with such a profile and your styles we can see your current settings (and please let us know which version of Civil 3D you have)
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 10
arman_zmn
Yes, i want to show the text with elevation at every profile vertices. Also a vestical line from the Datum Elevation (0m), both upwords for posetive elevation and downwards for the negetie elevations.
Also attached a dwg file for your reference
Message 4 of 10
Alfred.NESWADBA
which version of Civil 3D?
- alfred -
Alfred NESWADBA
Message 5 of 10
arman_zmn
- alfred -
Sorry, forgot to mention, I am using Civil3D 2017
Message 6 of 10
Alfred.NESWADBA
I'll create a video which shows the necessary steps, it's your decision if ..
  • I create that video in English Civil 3D, then I only have release 2019, so you have to do the same with your drawing (as my dwg-file created with 2019 can't be used with your version 2017)
  • I create that video in German Civil 3D 2017, then you can use the dwg-file I create during the video.
Sorry that I don't have version 2017 installed in English language.
- alfred -
Alfred NESWADBA
Message 7 of 10
arman_zmn
- alfred -
Hi Alfred,
No need to apologize.
I am familiar with Civil3D 2019. It will be great help if you could Create the video in English with Civil3D 2019.
I am not so good at German.
-Arman
Message 8 of 10
Alfred.NESWADBA
please find the video + the dwg-file (from Civil 3D 2019)
- alfred -
Alfred NESWADBA
Message 9 of 10
arman_zmn
Hay Alfred,
Thank you so much for taking time to make a vidio to help me with my problem.
I worked it out with Civil 3D 2017, just followed your instruction. It was a god send for me.
Thanks again, Keep up the good work.
-Arman
Message 10 of 10
Jowennl
Hi @arman.zmn,
I like @Alfred.NESWADBA's worklfow/solution above and I just want to add more information about your inquiry. Basically this is an alternative approach if you want to use the profile data band method to display all the labels.
Please see below or attached <screencast link> to guide you about Profile Data Band Method.
Attached two drawings below:
1. ProfileDesignProblem_2019_DataBandMethod.dwg
2. ProfileDesignProblem_2019_with Kilometer.dwg
Please see kilometer workflow:
Kilometer in Profile Band.pngKilometer Workflow 1-4Left Side before - km.pngKilometer Workflow 5Right Side after - km.pngKilometer Workflow 6
Cheers,
Jowenn
