Custom Model View of two viewports
gabriel.asbrink
gabriel.asbrink
Hey!
Im trying to find a way too save a custom model view that contains two viewports. For ex. a split model view where one shows the Profil and one shows corresponding alignment in plan.
Is there a way for my to save both under the same cusom view or do I need to save them as two separate views?
rl_jackson
The 2-view process is just the way it's hard coded into the viewport properties, so I would think even programable there wouldn't be an option to achieve what you're looking for. Besides the two reside in different places within the model, so what is the harm of the 2 views what exactly are you trying to achieve considering that a plan/alignment view may be longer or shorter that a profile view, the only time they match is when there a straight line.
Rick Jackson
Survey CAD Technician VI
gabriel.asbrink
It´s more for easier navigation, since I have a model that contains around 20 alignment over a large area with corresponding profile connected to them. So there isn´t a real need for the whole alignment or profile to be shown, just so I have it easier to jump between places.
Too bad there isn´t any way for me to do that. I´m new with asking questions on here, so should I close the tread or select you comment as the solution for people to know there isn´t one?
lim.wendy
Hi Gabriel,
Welcome to the Autodesk Civil 3D Forum. Thanks for reaching out to the forum. I'm glad you found Rick's explanation helpful. I'll go ahead and mark this as "Solved." This won't prevent other folks from commenting on this question though, in the event other ideas come up!
Remember to mark your posts as having an "Accepted Solution" if a solution is found as it helps other forum users with the same issue – so don't be shy about marking it as a solution! Accepted solutions get viewed more and help more users find the answer to their problems. . You could unmark the post as an accepted solution if the solution did not work. Click the ellipsis menu  > Not the Solution to cancel an accepted answer.
I hope you'll come back often to benefit from our Forums, Training Videos, User Groups and other resources.
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
