Custom Dynamic North Arrow Rotation Issues
Hello All,
I have created a north arrow that is capable of rotating to align with the viewport and it works fine for the most part. It is pretty simple where NORTH is written at the bottom and above that is an arrow in a circle. The way I want it to function is the circle and arrow rotate and the NORTH lettering stays the same. When I link it to a viewport it works fine. But when I use it as part of my dwt file for a trail alignment, the entire block rotates including the NORTH when generating my sheets. Might anyone know why this would be? I can remove it and then add in the same block manually and it will be correct but it sure would be nice for it to just work. Any information would be much appreciate!
wfberry
A case in point.  I know there have been problems with using North Rotation with the North Arrow.  Not sure if it has ever been corrected.
Bill
