Curves with radius under XX' plotting lighter than lines or curves with larger R
Having a plotting issue with a a few specific drawings that is driving us nuts. Some parts of a polyline segment print thin, while others print normaly. Staight segements and segements with a larger radius plot normally, the tighter radius spots plot thinner.
Here are the facts that I know.
If I print right from autocad to plotter everything prints normarlly.
If I publish a PDF set using the DWG to PDF, I can see the lineweight change in the PDF (almost appears as a line shift with slight overlap) and and it will print to the plotter.
These changes are happening accross a single polyline, and I verified global width set to 0
We use PDFs alot for the storage of print sets and sending to agencies. All project coordinators use PDFs to run the prints as required for clients/submittals so creating a plot file set is not a good solution.
This is happening only in a couple of drawings out of a hundreds a month. Al drawings started from the same template file.
Not sure how to proceed here. I attached a screenshot of what the PDF looks like. When printed (via PDF to KIP print) it goes from normal polyline width (0.30mm) to super thin (0.00-0.09mm) where I marked on the screenshot.
This is all occuring on Civil 3D 2016.
