when using label style composer with text on a curve as soon as you add a parentheses the jump up to the bottom of the text instead of staying in the middle. When the text is set to allow curve text to false the parentheses go back to the middle where they belong.
need a fix bad
Solved by Jeff_M. Go to Solution.
Hi Ed, Weclome to the forums!
Placing Text along an arc does some strange things, the parenthesis issue is one of them. You can work around this by creating 2 additional text components, one for each of the parens. Set those to NOT be curved, then attach each to the sleft & right sides of the arc text component.
Thanks for the quick response Jeff_m.
I should have mention i'm new at this way of label things civil 3d 2017
my label style composer only has name, visibility, used in, anchor component and anchor point and in the anchor component there is no text.1
you mention creating two extra text components and then attach them to the curve text
i tried that with component 2, didn't work i'am missing something
still confused
ed
Ed, the Text.1 is the first label component, it could be your radius, delta, length, whatever. I chose to edit a Parcel curve label, which is why there is the extra option of Span outside segments.
Edit, I'm attaching a dwg with a General Curve Label style setup as I described which should help.
