curb return of intersection at elevation 0
engsam777
engsam777
my curb return always at elevation 0, anyone have solution to this problem?
ecfernandez
Hi @engsam777, check these four things to find the problem
1. Layout profile. check that you have assigned the right profile to your corridor.
2. Check the beginning and the end of your layout profile to ensure it goes from the start to the end.
3. Check your assembly. Sometimes the subassemblies end up unassociated from the assembly (when you copy and paste them) and it causes strange results.
4. The beginning and the end of the layout profile shouldn't be PCV or PTV, sometimes it causes that.
I hope this helps. Best regards!
Camilo Fernández
P.Eng | Transportation
LinkedIn
