Curb Corridor Surface Corners not modeling correctly
kadebrunson
kadebrunson
Hey all,
I developed a workflow for grading parking lots. I use a feature line at the edge of pavement and set elevations, then run a curb only assembly down the feature lines, then do a grading infill on the parking lot and add feature lines as necessary for drainage.
For some reason, the corners in my curb surface are not turning out right. It's like the boundary is shooting across the corners rather than going all the way to the extents of the corridor. Does anyone know a solution to this or know of a better workflow which will avoid this issue? I'll attach a picture of what I'm describing.
Thanks!
cwr-pae
It's from the way corridors build themselves.
You can create a new region at the corner with really close spacing (0.1 or so) on the assemblies. Or radius the corners by a really small amount - 0.01 usually works pretty well and isn't very noticeable. Or insert a region just before and just after (0.01 each way), don't assign an assembly to the region and draw a FL to fill the area at the back of curb, snap to the curb back on each end and set the same elevation at the middle, then add the FL to your surface.
Each has its own advantages and drawbacks. Personally, I almost always use the curve.
kadebrunson
Awesome, thanks. Do you know of a way to fillet a feature line or am I going to have to recreate and reassign elevations?
cwr-pae
In the ribbon when you select a FL or type "FilletFeature". Pay attention to the command line after invoking.
Kevin.Spear
pretty easy actually. All horizontal and vertical editing of a feature line is in the C3D contextual tab for FL's. https://help.autodesk.com/view/CIV3D/2024/ENU/?guid=GUID-516C0333-EA36-40EF-9672-B99ADBD57BFD
Kevin
Kevin Spear, PE
kadebrunson
I'm not sure how I've never seen that. Thank you a ton.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
