Curb and Gutter with variable top height.
mazin_siwan
mazin_siwan
I'm attempting to create or design a custom curb and gutter using Composer Autodesk, similar to the one depicted in the picture. The top of the curb is intended to have a variable height due to the varying locations of driveways. However, when I adjust the curb height to zero, the edge curve remains unaffected, resulting in a discrepancy similar to the image below. How can I make the size of the curve variable or the radius of the curve reach 0 radius?
Replies (14)
Udo_Huebner
Make a Decision
If Radius = 0 then ...
Upload your PKT File.
Gruß Udo Hübner (CAD-Huebner)
AllenJessup
I could never get that to work. I ended up disregarding the curves. I can't see that affecting the quantities much unless you have miles of corridor.
Try reading THIS thread and see if any ot the suggestions help you.
Allen Jessup
CAD Manager - Designer
mazin_siwan
I also worry about the proposed front curb feature line and the profile for it.
mazin_siwan
I am trying to make it work by using an elevation target.
BrianHailey
I agree with what was said earlier, about removing the arcs. If you remove the arcs, what meaningful functionality/information are you losing? Will it affect quantities? Will it change the way it's built? What changes?
When I was a young engineer, I remember a surveyor telling me, "Brian, design it to the thousandth, stake it to the hundredth, build it to the tenth."
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
AllenJessup
I was basically told the exact same thing. A long time ago.
Allen Jessup
AllenJessup
Do you control the front (Bottom) of curb elevation with a profile and featureline? I let the Assembly handle that and only use featureline as a Horizontal Target.
Allen Jessup
Joe-Bouza
All with string, chaulk, hands and a dozer... in the olden days
Joe Bouza
cwr001
I agree with removing unneccesary complications but wouldn't this precisely mean that the arcs should be accounted for? 😉
@mazin_siwan
Your post doesn't state how you want the subassembly to behave in those cases but you can achieve different behavieours by using decisions. Just make sure that you account for the extra points and links in your shapes. (see the attached *.pkt-file; make sure to rename it from *.zip to *.pkt to open it)
mazin_siwan
Thank you so much for taking the time to create a model for it. Unfortunately, I tried to open the attachment many times, but I could not. I used the below link concept to rename it but still does not change or open.
https://www.youtube.com/watch?v=ry2dT1YQq18&t=47s
cwr001
There's no need to unpack or extract anything. After downloading, simply right click on the "CurbVarHeight.zip" file and rename it from "CurbVarHeight.zip" to "CurbVarHeight.pkt". Afterwards you should be able to open it in Sub Assembly Composer.
If your Windows doesn't show file-extensions, check this link to make them visible.
I've created this assembly in the 2024-version of Sub Assembly Composer, it won't work in earlier versions.
mazin_siwan
Thank you so much. I changed the extension, but it is still not open.
mazin_siwan
Below is what I get when I try to open it.
cwr001
This message occurs when you are trying to open an assembly that was created in SAC 2024 with an ealier version.
When you open your subassembly, look at the top line of the program and tell us the version you are using.
If you share your own *.pkt-file, people can also take a look and edit it right there!
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
