Announcements
Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Civil 3D Forum
cross section view - daylight
2 REPLIES 2
alexandru.murariu1989
587 Views, 2 Replies
I wanna draw a sidewalk, I made an assembly with a subassembly from polyline (a curb) and daylight after that subbassembly, when i generate cros section view as u can see in the attachement, daylight doesn t work and  i don t know why...
And 2nd problem is how can i represent in cros section view the road, even if the road is not the main object, will be nice to be in cros section views. Atleast a marker to represent the center of the road, and the distance between sidewalk and center of the road.
Ty Sirs!
2 REPLIES 2
For the 1st problem you have not set the surface target for daylight section in every region.
For second part I hope you can use Profile grade lines.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
Hello @alexandru.murariu1989 ,
Just checking to see if your problem has been solved. Did the response from @Jeew-m help answer your question? If yes, please click on the "Accept as Solution" button in his reply so this helps other users in the community find the solution too. Thanks!
Lynn Zhang
Rail Community
