Cross Section label display drawing name when referenced
m_kingdon
Advisor Advisor
m_kingdon
Hi all,
A have several alignments to display existing and proposed profiles cross sections with some feature lines displaying existing services.  When I reference these cross sections, the crossing labels display the drawing origin name, which is really not useful.
AfterAfterBeforeBefore
The crossing label is written to show the object's layer.
Mike Kingdon
Civil 3D Zealot
cwr-pae
When you xref a drawing, all the layers names of the source have the source file name prefixed to make sure they remain unique. Kind of a necessary evil. Instead of using the object layer as the object name, if you are using a FL or alignment, you can give it a unique name and use the name in the label. C3d objects can also have a description that doesn't have to be unique and can be used in many label types.
m_kingdon
Thanks, makes sense.
Mike Kingdon
Civil 3D Zealot
