Cross Section Data Band Labels
adw1975
adw1975
I've been sifting through the Data Band styles and display and can't seem to locate where I control the how often the Band Labelling is displayed.
I'm looking to only show the Existing ground Levels at the same locations where the design labels occur. Is this a simple fix?
See attached image:
I only want to show the labels in the Blue circles (corresponding to where design grade changes)
Jowennl
Please select your section view and right click and go to section property. Go to data band and change section 1 as design surface and section 2 as existing surface.
You can do it in all your cross section by clicking the section view group properties and amend the data inside your data bands and just make sure section 1 assigned to design surface and section 2 assigned as existing surface and that will do the trick.
You can visit this <thread link> and see my post number 6 and you can see in my screen cast at 2:05 I assign design surface in section 1 and existing surface in section 2. That screencast may also guide you about weeding.
Cheers,
Jowenn
adw1975
Thanks Jowenn,
That worked a treat.
I am having this same issue with my existing ground band even though section 1 is set to my design and section 2 is set to existing ground. I cant get it to display the correct level at the correct location.
I can however get my design band to show the existing ground level in the right place.
Any ideas how i can get my existing band to display the correct information?
