Civil 3D Forum
Creation of Pressure Network and add pressure pipe in it via C3D API
6 REPLIES 6
Pravin_Lande
1101 Views, 6 Replies
Is there any API functionality available by which we can create Pressure Pipes from selecting Polylines and after that adding that Pressure pipes to Single Network.
6 REPLIES 6
The Pressure Pipe API allow .Create, then you call .AddXxxx methods to add pipes.
Note you need the AeccPressurePipeMgd reference.
Augusto Goncalves
Twitter @augustomaia
Autodesk Developer Network
Hi I tried to Create Pressure Network and now want to add LinePipe to it. AddLinepipe requires two parameters first as LineSegment3D and another is PressurePartSize. When I am trying to fetch PressurePartSize, its giving me error as PressurePartSize is not accessible as its Friend. Kindly suggest how can I add LinePipe to PressureNetwork.
@augusto.goncalves,
Is this actually working? I've discussed with you at least once that I've never been able to get the Pressure Pipes API to work. I have tried to obtain parts from the selection or information above various components in the Pressure Pipe Network and have never been successful.
Steve Hill,Civil Designer / .NET Developer / AutoCAD and AutoCAD Civil 3D Certified Professional
http://redtransitconsultants.com/
Autodesk Exchange Store
Twitter | LinkedIn | YouTube
Ok, sorry my mistake here, indeed the PressurePartSize is not exposed (marked as internal).
Augusto Goncalves
Thanks Augusto.
There are many items not working, even if they are exposed, within the Pressure Pipes API. Really would love to see this get implemented so that developers outside of Autodesk can jump in and start creating some solutions to help improve the areas where Pressure Pipes are lacking - at least with a 3rd party solution. Have had many customers ask if I offer tools or if anyone I know of does.....
@Pravin_Lande
I've filed a case for pressure pipe support at ideas forum, please consider to go there and give it a vote if you want it to be done quickly
Rail Community
