Creating Surface from DEM and editing it
nasko88
nasko88
I've made a lidar scan of a river (around 2.5km long) and now I have a DEM file of the terrain. We've also measured the river points with GPS reciever.
I am working with Civil 3d 2025 and want to create Surface from it, so what I do is in Surface into DEM files I select my DEM. So far so good, evrtithing is going smootly. Now I've created a feature lines from points, measured with GPS.
Now I want to insert the featurelines into Surface (with DEM inserted already) as a breaklines. When I try to do that it comes error cause the breaklines crosses triangles of the DEM file. So what should I do and what are the best practices working with DEM? And how I can easyli edit DEM Surface in areas where point classification failed and should be manually flattened?
P.S. I am attaching some pic, where it can easily see that the Surface has to be editted. With Red are the featurelines which I want to insert as breaklines.
Jeew-m
THIS would help you.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
Joe-Bouza
I would go with composite surface.
Blank EG
FL Surface
DEM Surface
Paste DEM into EG, then FL surface
Joe Bouza
