Creating Points Problem
JohnC_ISM
Message 1 of 8
JohnC_ISM
i cannot figure out why when creating points it wont let me select the point style its greyed out to STANDARD and then in the point creation menu i set the settings that i can change such as automatic label or whatever else. then after exiting it resets the point creation settings.
Replies (7)
Message 2 of 8
AllenJessup
You have to edit the command settings to allow an override. Or change the default to something you always want to use.
Allen Jessup
CAD Manager - Designer
Message 3 of 8
JohnC_ISM
Ive already changed it to put it into the standard points, I meant to say it goes to default style which is a cross hair so small you can barely see it. The standard is the greyed out yet it still goes to the option.
Message 4 of 8
Pointdump
Hi Stephen,
Change Disable Description Keys to "True". Then Default Styles won't be greyed out.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
Message 5 of 8
JohnC_ISM
Okay that worked. So now how do I get it to stay as true because once you close point creation it resets
Message 6 of 8
Pointdump
Under the Settings Tab >> Point >> Commands >> Create Points >> Edit Command Settings, check if you have any overrides, child overrides, or locks.
Dave
Dave Stoll
Las Vegas, Nevada
Message 7 of 8
JohnC_ISM
Nope. No overrides. That's the first time even seeing that menu so I know I didn't mess with anything in there.
Message 8 of 8
user181
To get the changes to stay, edit the command settings and under General change "Save command changes to settings" to Yes
