Announcements
Creating Custom Subassembly With Dynamci Codes in Subassembly Composer
khaledCULN8
khaledCULN8
is there a way to create a custom subassembly with dynamic Codes?
meaning that if i can change the codes not only in subassembly composer, but also in civil 3D.
there in one subassembly in the civil 3D library that allow to change the Codes as I Like --> Generic Pavement Structure
can i create in SAC a custom subassembly like that?
thank you in Advance
Khaled
KMercier_C3D
In SAC you can create an Input Parameter that is Type=String and that will allow you to have dynamic codes.
For example, if you have a string Input Parameter called SurfaceLinkCodes and set the result to Top,Pave1.
Then in when you define L1 instead of putting "Top,Pave1" in the Link Codes you can put SurfaceLinkCodes (note that you do not use the quotes since it is a variable.
Kati Mercier, P.E. | LinkedIn | AutoCAD Civil 3D Certified Professional
Pronouns: She/Her
Co-author of "Mastering AutoCAD Civil 3D 2013"
AU2019 Speaker::: CES321590: Analyze and Revise Existing Subassembly Composer PKT Files for AutoCAD Civil 3D
AU2017 Speaker::: CI125544: Analyze and Devise in Subassembly Composer
AU2012 Speaker::: CI3001: Reverse Engineering with Subassembly Composer for AutoCAD Civil 3D
AU2011 Speaker::: CI4252: Create Subassemblies That Think Outside the Box With Subassembly Composer for AutoCAD® Civil 3D®
lynn_zhang
Hello @khaledCULN8 ,
Just checking to see if your problem has been solved. Did the response from @KMercier_C3D help answer your question? If yes, please click on the "Accept as Solution" button in her reply so this helps other users in the community find the solution too. Thanks!
Lynn Zhang
