Creating breaklines from polylines
Typically I make feature lines and define them as breaklines. If line work isn't shot in while doing the survey, then I have to manually draw it in by using the PL command and choosing each point. I'm going to need most of the line work to show on the plan sheet. Then I have to somehow create breaklines. If I don't create feature lines to do it, can I just add the polylines to the surface as breaklines? Will this affect the surface?
If you look at the properties of one of those polylines is gives you one elevation compared to a feature line which has multiple elevations.
