Create vertices at intersection of contour lines and sample line/section lines
 Hi There,
Please excuse me if I incorrectly use any terminology, I am pretty new to this field.
I have generated a contour map of a canal with a center alignment and samples lines at every 20 meters (where we generated cross sections). I also have a point cloud from which we have created a surface and the contours.
From the cross section drawings it is easy to see the elevations at the extents of either side of the canal, however we would like to add vertices on the contour map itself with elevation labels at the extents of the canal. Doing this manually will take a long time. I realize using the sample line may not be an option, but we can make that a polyline as well.
I assume there is a way, using the create ground points tools, to do this, but have not had luck. Attached is a sketch of where we would like the vertices. Using the create points at intersections I can't get it to use the contours as a selection. Using the create points from surface I am able to get points, but only at a fixed interval along the contour lines. Even if I set the interval to 20m, the same as the section intervals, they don't match exactly, I assume because the canal is not straight.
Any help is really appreciated!
You can extract contours from a surface to get 2d polylines if that is what you need in order to snap to intersection or apparent intersection. You can also set points, or label elevations, on a surface randomly - that is, wherever you click. I don't know of a way to do this automatically, I think you still need to click at every vertice intersection.
MMcCall402
Try using a contour label.  The labels use a 'line' for their placement that could easily be edited to coincide with the section line and produce a label at each contour intersection. The label style can be made to produce a label to whatever precision you need.
Use the Contour - Multiple and you'll just need to pick each end of the section line.
Mark Mccall
CAD Mangler
VHB - Engineering, Inc.
