CREATE SURFACE BY USING POINT GROUPS
I am new to civil 3D. I have an existing file with point groups. How can I add those groups to create surfaces.
autoMick
Hi and welcome to the forum.
What you need to do is right-click on the surfaces heading in the prospector (left hand menu drop down lists). Create a new surface, give it a name and set an appropriate style.
This will create a new empty surface.
Now expand the definition for this surface in the prospector, right click the point groups sub-item and that will allow you to add a point group (or multiple point groups).
Cheers
- Mick
Civil3d user in Australia since 2012.
Ok thanks. It works.
autoMick
Great... so you should click "Accept as Solution" on that response so then people know that you've got the answer you need
Cheers
- Mick
